15 HP Two stroke running with pulser coil disconnected???? Rodnut ring in here
  • 15 HP Two stroke running with pulser coil disconnected???? Rodnut ring in here
    A guy is reporting that his 15 HP will run (at a fast idle) with the pulser coil disconnected. I would not have thought so but...
    The fact that he says it runs at a fast idle might be telling us something. I don't know what it is.
    Ever seen this?
    my unicorn needs to be fed.
    maybe I will use my magic wand cause it is raining a bit.
      That is not warm rain you are feeling on your leg.
        without the pulser to tell it when to fire, would it just not fire the spark?
        or could it default to fire at some point?
        maybe with an ECU it might,
          I would have thought that the engine would not run. A guy is telling me that it does. But who knows. He might not even be disconnecting the pulser coil.
