Vin #
  • Vin #
    C85tlrp 688 l 415045
    i got this motor on my boat. Any body can tell me what yer is it?
    I try pool motor up by switch and i here noise but it doz not move
    It's a 1991
      How can i pol up motor if power trim not work?
          thanks ,I lift motor. After this two little cylinders move up and down but big cylinder not work, any maintenance or repair ?
            low on fluid maybe
              how can I add it and what kind of fluid
                find a service or maybe an owners manual for that motor
                  any body can help me how can I add it and what kind of fluid
                    Dexron II or III power steering fluid is the recommended fluid.
                    With the motor in the full up position, remove the cap to the reservoir. Add as much as it will take. Replace the cap. Trim down and back up. Check the fluid level. Add if needed.
                    Repeat the process until there comes the time that no more fluid can be added.
                    If it does not work correctly now then maintenance/repair is needed to the ptt assembly.
                      If you will go to Yamaha US' website and look at some owner's manuals you can find the answers on your own. With photos that help.
                      Just find a motor that is similar to you own if you can find a C85.
                        thanks, I GOT IN MY GARAGE PENNZOIL MARINE POWER TRIM&TILT FLUID
                        .CAN I ADD THIS INSTEAD Dexron II ORIII power steering fluid
                          If it is a marine power trim and tilt fluid it should be just fine.
                            thank you very mach!!!
                              Hi again,i made water test ,only two or one cylinders work .i put new spark plugs, doz not help. May by carburetors? Wot caind strongest chemicals you can recommend for beginning
