My F150 is making a high pitch whining sound but not loud kinda like turbine sound at mid to high rpm . I’m not sure if this is normal. Motor has 70 hrs on it
2017 F150 whining sound
https://www.youtube.com/watch?v=LQvC...ature=youtu.be
here a short video of the sound . It’s like a ring sound .
I can't hear it....
Maybe with a helper and the cowl off the recording would be better...
*When my mid shaft bushing was dry, it would "squeak" at about 1,800 RPM's. I would literally be looking around for a nest of birds....
You aren't in SW Florida are you?Scott
I don't hear anything abnormal. There are a couple videos on YouTube regarding noisy balancers. Not hearing that.
I would keep on boating. Issues typically get worse and I am betting there is no issue.
I'll listen a little closer to my motor this weekend.
I don't know if Rodbolt can view YouTube........
dude. it should be under warrenty still.
take it to a pro.
use the Yamaha dealer locator and find a shop with at least one master tech.
if it is a balancer and it fails it typically takes the power head with it.
takes about 1 hour to change a balancer.
takes me about 16 to change a power head.
Originally posted by rodbolt17 View Postdude. it should be under warrenty still.
take it to a pro.
Be better to have a video with motor idling with cowl off to listen for balancer,
maybe revving it slightly.
ÂÂÂ
