Going thru a customers carb (F8 MSH), (doesn't idle) after being submerged in brackish water (not running).
It was washed / got running the same day however (as noted) doesn't idle W/O the choke.
Carb was just disassembled by myself, lots of dirt / crud (not varnish) inside (literally falling out as I removed a jet) and a very clogged and FROZEN low speed jet. That eventually came out with an Easy Out and a new one ordered.
Anyway, looked for the shop manual (found the owners manual). The usual link didn't show the F8.
** I need the initial # of turns out for the AIR SCREW (should be under the sealed cover-but isn't). It WAS screwed fully in.
If someone has that setting #, it'd be appreciated.
Tks, Scott
BTW, per the parts manual (two versions of this engine) there is no accelerator pump, which this one clearly has (and was corroded /seized). Neat set up...
Tks, Scott
