2004 Yamaha 90 HP 90TLRC outboard. Erratic or intermittent tachometer operation. This is an analog gauge, not digital. Acts like a loose wire, but checked all connections to the tach, no loose wire. I understand this signal is transmitted through the voltage regulator. Is that correct and what's the likely cause?
Tachometer
