2006 f150 not turning off
  • 2006 f150 not turning off
    When key is turned off motor will not go off for about 30 seconds or more. Replaced switch and did not help. Would like more solutions, PLEASE.
    What happens when you pull the kill switch?
      Still won't shut off.
        Does it make a noise like it is going on and off sputtering , sounds like timing could be advanced. No expert but I had a similar problem and it was the timing.
          No, it just keeps idling normal for a little while and then cuts off. Sometimes 10 seconds and sometimes 30 seconds.
            I believe some motors have to go through a shut down cycle when key is turned off before motor dies, but do not think it should take 30 seconds
              you either have a bad ground connection, a main relay sticking or the ECU is going south.
              the ECU has to cycle down and reset the ISC valve at shutdown.
                Thank you for the replies, I'll check all ground connections and main relay. Hope it's not the ECU.
