Engine has developed a starvation habit, runs maybe 30 - 45 seconds at or near full throttle before laying down. I replaced fuel/water separator filter, and cleaned/rebuilt carbs. At idle, pressure test after fuel pump showed about 2.5 psi, and vacuum test before pump showed about 3 in.
I know I need to test at WOT, but I'm hoping that these numbers would be low enough to warrant replacing the fuel pump, and save me the potential inconvenience of going into the fuel tank, under the floor, with access under the console. Anymore, when I get down there, it's questionable if I'll ever get back up. Can someone please tell me it's obviously the fuel pump? Specs for the psi and vacuum numbers aren't that easy to find. Thanks.
