prop
  • prop
    What size prop do I need ? I have a 2003 2 stroke, 50 hp. yamaha, it's on a 16 ' check mate. It has a 11.6 x 11 on it now, rpms. 4200.
    Go to this site, it should be helpful:
    Performance Bulletins | Yamaha Outboards
      I do not know what a Check Mate is so looked up on web.
      Did not find anything about that small of a boat, only a lot larger.
      Could be the boat is heavy and is way under powered with a 50.
      What does the plate say the max HP boat is rated for?
      11 pitch prop is a low pitch and you are not getting to the proper WOT RPMs.
      Could be a motor problem, a set up problem, or boat is just too heavy due to water in hull
