2006 Yamaha 150 2 stroke
  • #31
    Try re-checking the compression in the bad cylinder with a just a little 2 stroke oil in the cylinder and see if it rises.
    Should it rise, it points towards the rings. If it does not, your probably looking at potentially a head gasket, corroded head.
    How does the spark plug in the bad cylinder look?
    Also, what "looks like it's repaired before", please elaborate.
    • #32
      the old oil trick is worthless in a two stroke and terribly messy.
      bore scope it or pull the head.
      however this is not your intermittent issue.
      mechanical failures do not come and go.
      • #33
        I've used this method on small two strokes and it does in-deed work.
        Were talking maybe two teaspoons and not messy at all.
        Depending on the normal compression I've seen it raise usually around 30 PSI..
        **I've had some (two exactly) engines, not run for years (2 stroke weed eater and chain saw)and won't start with fuel, compression, etc. Add a tad of oil to the top end, the engine would crank up and run great after that... I assume/think the little bit of extra sealing, helped pull in fuel...
        • #34
          oil will not help his motor, and it will not tell him what his problem is with that cylinder.
          inspection is needed
