Might be better to ask this question over on The Hull Truth. Then sit back and enjoy the arguments.
Some will argue the superiority of 100% synthetic oil and then will go so far as to argue the merits of a particular brand of 100% synthetic. The brand I use is inherently superior to the brand you use.
My belief is that for 99.999% of all motors there will be virtually nil benefit seen via the use of 100% synthetic oil. If one feels he is part of the 0.001% he might benefit from the use of it.
Let the discussions begin. Then we can debate the weights of the oil.
Well, I think that 99.999% is an exaggeration. It's probably more like 99.997%. But, I agree - use an oil that fits within the specs offered by Yamaha and you're good to go. Maintenance and regular oil chages are more important. If you want some reading material, google something for the benefits of sythetic vs conventional oil After 18 hours of reading, you'll be right back to where you started.
My belief is that for 99.999% of all ENGINES there will be virtually nil benefit seen via the use of 100% synthetic oil. If one feels he is part of the 0.001% he might benefit from the use of it.
Yamaha Motor Corporation
Ford Motor Corporation
Continental Motors
General Motors Corporation
Toyota Motor Corporation
Honda Motor Company
Bavarian Motor Works
Kia Motor Corporation
Hyundai Motor Company
Porsche Automobil
and about a jillion more
synthetic costs more , but you can run it longer
I did not try to figure out if it evens out in the long run.
but it does save some of the maintenance time if you put a lot of hours or miles on a vehicle causing more than 0ne oil change a year
Continental Motors
Honda Motor Company
Porsche Automobil
You need to heed the direction at THT. Don’t fight it so much. Stop having so much fun!!!
