Yamalube oil full synthetic
  • Yamalube oil full synthetic
    Hi,
    What would be the benefits if any to use the yamalube 5w30 full synthetic in a F115?
    Oh boy.
    Might be better to ask this question over on The Hull Truth. Then sit back and enjoy the arguments.
    Some will argue the superiority of 100% synthetic oil and then will go so far as to argue the merits of a particular brand of 100% synthetic. The brand I use is inherently superior to the brand you use.
    My belief is that for 99.999% of all motors there will be virtually nil benefit seen via the use of 100% synthetic oil. If one feels he is part of the 0.001% he might benefit from the use of it.
    Let the discussions begin. Then we can debate the weights of the oil.
      Well, I think that 99.999% is an exaggeration. It's probably more like 99.997%. But, I agree - use an oil that fits within the specs offered by Yamaha and you're good to go. Maintenance and regular oil chages are more important. If you want some reading material, google something for the benefits of sythetic vs conventional oil After 18 hours of reading, you'll be right back to where you started.
        Oh boy.
        My belief is that for 99.999% of all ENGINES there will be virtually nil benefit seen via the use of 100% synthetic oil. If one feels he is part of the 0.001% he might benefit from the use of it.
        Fixed it for you
          Fixed it for you
          Fixed what?
          Are they all wrong?
          Yamaha Motor Corporation
          Ford Motor Corporation
          Continental Motors
          General Motors Corporation
          Toyota Motor Corporation
          Honda Motor Company
          Bavarian Motor Works
          Kia Motor Corporation
          Hyundai Motor Company
          Porsche Automobil
          and about a jillion more
            IMO, anyone interested in motor oil should have a look at this blog:
            https://540ratblog.wordpress.com/201...-test-ranking/
            An excerpt:
            * Synthetic oils rank between number 1 and number 221.
            * Conventional oils (with no aftermarket additives) rank between number 4 and number 223.
            * Since the ranking of synthetic oils and conventional oils completely overlap,
            there is no clear distinction between their wear protection capabilities,
              IMO, anyone interested in engine oil should have a look at this blog:
              An excerpt:
              Fixed it for you. You are welcome.
                Semantics fight!!!! Are we on THT?
                Dennis
                  There are two benefactors. Yamaha and the oil company who supplies Yamaha.
                  My two cents.
                    synthetic costs more , but you can run it longer
                    I did not try to figure out if it evens out in the long run.
                    but it does save some of the maintenance time if you put a lot of hours or miles on a vehicle causing more than 0ne oil change a year
                      Fixed what?
                      Are they all wrong?
                      Continental Motors
                      Honda Motor Company
                      Porsche Automobil
                      You need to heed the direction at THT. Don’t fight it so much. Stop having so much fun!!!
                        ok I guess better to save $$$ on other stuff I will stick to 10w40.
