Hi All,
I normally work on restoring the vintage and classic wooden runabouts and am quite familiar with those early inboard systems and methods. Currently, a customer and I are building a 24' Glen-L designed boat with an enclosed pilot house and cuddy cabin.
This design could be either inboard or outboard. Customer / owner chose to use outboard on an Armstrong stern mount. About 2ft.aft of the transom. Owner has chosen to use a new Yamaha F200 for power.
We have had a custom built, AYBC compliant, fuel tank built to the space available in between the boats main stringers. Also have a LARGE single 12 volt battery between the stringers.
Our location is in central Iowa and the closest Yamaha dealer is about 100 miles away and they generally buy boat packages with the motors already factory installed. They have not yet done a complete stand alone 200 horse install. They say that Yamaha might not be willing to sell a single unit to a small dealer. We'll see. So we're kind of flying solo here.
Right now, our focus is building the helm station along with its instrumentation and controls. We are trying to decide which type of instruments to use analog or multi-function. I have apprehension about the multi-function gauges and what happens if one part of those instruments fails. Do you lose all info from that gauge or just one element? It seems to me that analog instruments would be easier to trace and trouble shoot.
We have and are using Yamaha's online rigging catalog and I don't find a good wiring and control layout for analog instruments using a binnacle shift / throttle control box. Is there another source for such a diagram ?? So far, we're using the "Rigging Order Guide for Mechanical control and Multi-function Gauges" in the rigging catalog to very soon start ordering components. I would like to have most of these items on hand so I have no surprises as I build the dash panel.
I read that there is a kit that is added to some motors for a speedometer pitot tube pickup in the lower unit. This is used to feed a pressure signal to instruments. Is this built into a new F200 already ??
Question: Could someone outline the usual components that go in the rigging tube between the transom and the motor - I presume the hydraulic steering hoses don't.
Question: Is there a wire color code for the wires in Yamaha harnesses ??
Question: On the 6Y5-83553-N0-00 Gauge Harness there are yellow and blue wires stubbed out the side of the harness. What are they for ?? What can they be used for ??
Question: Can Rigging items be purchased thru this source.
That's it for now I'm sure I'll have more soon
Paul
Paul
