I bought this motor used it had been overheated and sitting up for a while. Head gasket was blown, resurfaced head and replaced gasket, replaced water pump assy, flushed all the sand from lower unit and cylinder head that caused overheat to start with. Cleaned carb engine cranks and idles great, cooling system does well will idle all day but will only rev to about 1500 rpm, it acts like its in some kind of limp mode. It has 135lbs compression on each cylinder and is firing on both cylinders was wondering if there is a test for the CDI module or a wiring schematic that I can get to be sure its getting all the right inputs for the CDI module. Or can the module be reset or flashed to bring it back on line. Any help would be appreciated thanks
2003 25hp 4 stroke yamaha F25ELHB
pick up a Yamaha service manual for your motor and follow the steps for testing ignition system.
Do not just guess some things are in spec , test them.
Or take it to someone that can test
Did you read what Rod wrote?
He put an if in that post
Originally posted by rodbolt17 View Postif pulser coil and charge coil inputs are good, most likely the CDI died.
the ign advance is electronically con*****ed by the CDI based on pulser coil inputs.Last edited by 99yam40; 03-18-2014, 07:22 PM.
a fluke 78 without a DVA adapter wont correctly read DC voltage peak.
it does an average voltage.
you should see a minimum peak voltage of 6V cranking and a minimum peak of about 18V at 1500.
minimum of about 35V at 3500.
my guess if its not advancing the CDI is faulty.
it is a merc motorala ign system.
