I have a 2003 F115TLRB with 110 hours on it, original owner is me. The boat has run flawless other than last year I had to have the injectors sent out to be cleaned, cleaned VST, filters etc. It ran great for over 20 hours since then.....
This year after about four months storage (warm California indoor storage) the boat cut out a little. I removed all fuel, added new fuel with additives as usual, all seems well ..ran for a few hours fine after that. Well last time I took it out, it totally turned off under power and would crank but no start...got towed in. Trying to start while towed it sputtered and idled only for a second, then totally turned off...no fuel pump.
That night on the trailer, on ears, crank but no start several attempts. No fuel pump priming AT ALL When turning key on, but I would get the IAC noise. I let it sit for the night and thought I'd diagnose further in morning. In morning, turn key on, fuel pump primes perfectly, everything seemed ok again....so it was not able to be diagnosed.
What do I have to look at...I was thinking maybe main relay acted up? (68v-81950-00-00) or maybe the high pressure fuel pump was acting up,....but it now sounds perfect and I ran the boat two more days about 10 miles and ran perfect, no bogging, no nothing. Any ideas before I throw a part at it or am I going to have to do the dreaded wait till she quits again?
Thank you, I've been lurking on here forever finally have an issue that has me worried.
