Boscoe or Rodbolt on my 2004 F115tlrc Hurricane has a 704 Yamaha throttle control. Has the round button on the side to release throttle to engage throttle if running on muffs or in tank to increase RPM without engaging gears, but my question is should I be able to push the throttle lever into forward with the engine not running and move to full open position like you can if the engine is running? Never tried it but the one on this boat won't move to forward without the engine running or the neutral button depressed? Or is the throttle cable maybe hanging up somewhere? If the boat is under way the throttle is not tight or hard to push to full open.
Boscoe or Rodbolt 704 yamaha throttle control
If the stars and the moon are in alignment it can be done. It is designed to only be done when the motor is running. As normal practice I would not do it. Stuff can get bent.
The shift happens before the throttle can happen. Depending upon where the dog clutch is, the shift might not happen.Last edited by boscoe99; 06-11-2018, 11:14 PM.
Originally posted by boscoe99 View PostIf the stars and the moon are in alignment it can be done. It is designed to only be done when the motor is running. As normal practice I would not do it. Stuff can get bent.
With the neutral button depressed????
He's not looking to shift into gear W/O the engine running, IE, LU gears don't have to be aligned, no forcing anythingScott
If the button is pressed the shift mechanism is disengaged. The throttle can be advanced.
If the button is not pressed the motor may or may not shift into gear. If it does the throttle can be advanced. If it does not shift into gear the throttle can't be advanced. In the latter case if one tries to force it, it may go into gear or damage could happen.
difficult to understand exactly what the "question" is -
perhaps the OP would appreciate a youtube explaining how an outboard "shifts"
https://www.youtube.com/watch?v=9ib2OkytCBs
https://www.youtube.com/watch?v=hYPuB9nmS8E&t=53s
"my question is should I be able to push the throttle lever into forward with the engine not running and move to full open position like you can if the engine is running?"
I read his question as if the neutral button is not being pressed. Could be wrong. Again. Happened once before.
That is the way I understood it too Boscoe.
and yes I changed out a twisted shift shaft and bent pin thru prop shaft I am sure from someone trying to force my brothers C60 in to gear without it running. he was the 3rd owner and someone tried adjusting the shift cable to make up for the misalignment after the fact. I caught it when changing out water pump, and setting shift cable back to where it should have been.
But as Boscoe said if the dogs line up you can, there is nothing in the con*****er that keeps it from happening except for it has to go into gear 1st before throttle can move. shift cable not moving far enough in con*****er will not let throttle move ( maybe you can say the con*****er keeps it from happening after all)Last edited by 99yam40; 06-12-2018, 08:20 AM.
ÂÂÂÂ
