oil recirc nipples 250 TURY OX66
  • oil recirc nipples 250 TURY OX66
    need to replace some of the rusted fittings that go into the block. The little round ones that the oil circulates to. Are these just pressed in. ? Just some vice grips to pull them out? As usual, any help is appreciated.
    yep, light press fit.
    I usually clean the bore with carb cleaner and wipe a bit of gel seal or loc-tite 518 on the new one before gently pounding in place.
      Thanks Rodblt
      Appreciate it.
