Brand new with power tilt. Them trim stop pins are in the 3rd holes but i need to lower them 1 or 2 more. The pins arent able to come out as they hit the ram when trying to remove. Do you have to take the tilt ram out just to adjust the stops?
F20 Trim Adjustment
There's 7 different sub models, do you know the sub model?
Here's a pic of one: https://www.boats.net/catalog/yamaha...0112/bracket-2
I don't see ONE long pin (like the old Evinrudes). Can you pick out what part # the engine currently rests against?
2016 shop manual: https://www.vansoutboardparts.com/se...a-f15-f20/file
Does the owners manual not address how to adjust?
I didn't see anything in the shop manual, BUT it should be pretty simple. With the engine trimmed all the way up, there's still no room to R&R those "stops"?Scott
Originally posted by 99yam40 View Posttransom wedges may be needed to get proper angle of the motor at rest
Might have to remove the tilt unit to access them.
The parts diagram did show "tilt lock UP" PLATES, apparently for maintenance.Scott
I see five holes on the transom bracket to move the stop bolts to adjust the all the way down position. This a 2016 model I am looking at.
Must be in the owners manual how to move them to the desired position? Be a awful pain to have to remove the tilt assy to move the stops!!!
Must be missing something....
I don't see why you can't just move the current "stop" bolts to another position.
was thinking how my C40 on a 16ft aluminum boat came to me used with a tail on motor.
I took it off and 1st time running it out to the flats I had to get my brother to sit on the bow to keep it from porpoising with the trim all the way down.
transom wedges were the only fix I could think of , but putting the tail back on made it OK again
Originally posted by panasonic View PostI see five holes on the transom bracket to move the stop bolts to adjust the all the way down position. This a 2016 model I am looking at.
The owners manual does not address moving the stops on the power tilt model. I think they are intended to be fixed. But???
