My 1999 F40TLRX has never run real good. I inherited this engine as part of a 20' pontoon package from my father. I have been able to get it to run reasonably well for awhile by draining the fuel bowls and squirting carb cleaner into the bowl drain holes watching for debris. I've also completely disassembled the carbs, including the plugged orfices, being careful to return the screws to their previous settings. I use rec 90 fuel and stabilizer after taking it to an authorized Yamaha repair facility and being told that problem is bad gas. Nothing I do seems to remedy the problem long term. Start up this spring was extremely difficult. I believe it was due to excess fogging oil in the plugs. Spraying the plugs with cleaner resolved the no start. It now starts fine, but runs extremely rough between idle and 3,000 rpm. It runs great anywhere above 3,000rpm. I've seen some you tube video's about installing larger jets from a F25LA on the F40TLR's. Could I benefit from the same rejetting? The articles, and videos I've seen recommend changing the #38 and #95 jets to #45 & #108.
Is rec 90 a good fuel to use? Is Sea Foam ok to use? I read in another post about using Yamaha's "ring free". Would this additive be helpful in this situation? Also read about the ECM being a culprit.
Please, someone, HELP!
