Hows it going. I went out fishing last night and when I was running the boat slow I had no issue but as I went up in rpm about within a minute or two the primer bulb would be sucked in( bulb would be in the position as if someone squeezed it) and the boat would stall. Any suggestions on what the issues are? I’m using a new 6 gallon tank this year so not sure what could be going on.thanks
Primer bulb issue
yep you have to let air in if you pull fuel out.
I thought the new ones would let air in but not out. so gas fumes could not escape into the atmosphere
my old plastic tank has a small thumb screw on the cap you loosen to allow air into the tankLast edited by 99yam40; 05-26-2018, 03:48 PM.
They are supposed to let air in through the one way vent...but they don't always work.
Tank blows up like a football when left out in the sun....junk. Crack the cap to let some air in is all you can do. Or return it and try another one.
ÂÂÂÂÂÂ
