Originally posted by DennisG01
View Post
Engine Bog
Originally posted by DennisG01 View PostGeez, I dunno guys. Every single carb'd engine I've ever had... cars... boats (4-stroke and 2-stroke)... etc, etc. Has always had some type of bog on a cold engine and quick acceleration. I've owned quite a few boats, but I've run literally hundreds with my job. On smooth, con*****ed acceleration - no bog. But on quicker acceleration, yes.
Jasons in west Florida, water temp is about 80F, air temp even warmer.
Between the water temp, air temp, engine is still semi warm, it shouldn't bog.
Originally posted by Jason2tpa View PostThere is only 1 screw per carb that will effect the idle mix (lean/rich) that can be adjusted...the air adjustment screw.
there are air jets and fuel jets and passages that can plug or restrict proper flow.
I do not think that motor has a screw that just adjusts the amount of air
there are main jets that can be restricted also
also make sure the timing is advancing as it should and hit specLast edited by 99yam40; 05-28-2018, 08:46 AM.
Bone cold engine, cold water, start and nail it, I agree, you can get some bog (especially with the choke fully off)
Between the water temp, air temp, engine is still semi warm, it shouldn't bog.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Now the worst of the weather has passed I was able to drop boat in water and make carb adjustment. All it took was a 1/4 turn out each of the air adjustment screws, and I brought the idle speed up 100 rpms to the higher end of spec. Definitely made a difference.Jason
ÂÂÂ
