I sometimes get code 13, pulser coils, on my Yama f115, 2007. If I restart it usually goes away. Is there anything I could do myself before turning it in to a Yamaha-service center? Greetings from Sweden :-)
Yamaha f115, code 13
Originally posted by fairdeal View Postdo you have a voltmeter with peak voltage adapter? there is a spec for output values of the coils
Originally posted by boscoe99 View PostOn a problem that comes and goes I would first check all electrical connections. Inspect the wiring for chafes and nicks.
coils do not normally come and go.
OP the Yamaha service manual for your motor will have the specs, and procedures for testing.
if you did not notice, fairdeal mentioned the proper voltmeter and adapter
