12/10 F60LTR flushing at marina today, flush tube came off block and filled cowling
  • 12/10 F60LTR flushing at marina today, flush tube came off block and filled cowling
    Hey guys,
    I was flushing engine today and the rubber flush tube that facet hose connects too came off the block. Turned my back for a minute and the water was not coming out phole, but was leaking out cowling. Took off cowling and it was at least half full,.
    Engine only clicked after that. I hope it will start in the morn, will spray down with dryer and lube and try to start.
    Question though is where the heck does hose attach to block can’t find a thing on block or the good old internet. I thought maybe there was abinsert hole right above the entry point where hose comes into cowling but the tube goes up in the hole but doesn’t attach?
    Any thoughts, I surely do appreciate any help
    Thanks Rob
    ecaf5fa116f0626be68f50e5c45cda1c.jpg No help at all with your engine's specifics. But if it were mine, I'd pop the hood and carefully disconnect every electrical connector and get some kind of dryer going, like a nearby space-heater, or a plain old hair dryer. Maybe a fan, whatever. Not too hot, but hot enough to be blowing DRY air.
    Dry it out for a day or so, then come after that and spray electrical parts cleaner and some type of CRC type jizz or Astroglide or dielectric grease on all of the pins n sockets. Might not amount to much more than a few hours hassle at this point, but if you don't do it now, those mothers are sure to give you problems later. Electrons are picky.
    Don't take my advice blindly as I am sure there's a better way. I'd ask Mr. Google among others but I'd sure as hell get after it now, or pay her to do it.
      Your model doesn't show but a similar model:
      https://www.boats.net/catalog/yamaha...ttom-cowling-2
          Went over this morning and literally sprayed some T-9 all over. Then the starter kicked over and ran good. After it was running I could see the water running back out the tube. Fricking thing was under the aft end under the plastic intake and fuel rail right by the exit for the phole.
          Could not not get my mit in there to hook back up. Thought I was going to have to take the intake off to get it on. Found a wondering kid to stick his hand in there and get it back on.
          it seems good thanks all.
          Rob
            no it is NOT all good and WILL do it again.
            blown more little F motors than I care to see.
            there is a tech bulliten out on the F50,same design as the F/T 50 and 60.
            ALL hoses are to be tie strapped.
            blow that line when up and running and it fills the cowl faster than it can drain allowing a hydrolock on #4 cyl that results it a snapped rod and a broken block.
            trust me on this.
            nuts to lose a motor over a small tie strap.
              Thanks RB for the info. I will see what I can get on there to tie it on. I don’t see how but maybe a wire tie to tighten it up.
              kind of hard to do when in the water. I guess I will need to trailer it up and do something.
              I want a bigger OB but that’s not the way to ge lt it.
                trust me on this.
                What is the tech bulletin number Rod?
                  If you can get the kid to put the tube on you can get a zip tie on it too. Put the tie on the tube loosely and get the kid to slide tube back on nipple. Use some of those extra long needle nose pliers and a long screwdriver to tighten the zip tie. Pull it with the pliers and pin it down with the screwdriver. Does that make sense? I do it all the time but a little hard to convey... I would put the tube on with the pliers too. gently....
                    I guess it would be a good time to check all the hoses and make sure they themselves don't look like they can break, and have good ties on them.
                    Could that hose popping off be a symptom of water passages clogging up?
                      Not Rod but it is O2011-009.
                        Thanks "Not Rod"
                        Can I assume that the bulletin says check for tywrap on flush hose...if not there....put one there?
                        I ask cause I have a 2011 F60 to look after...
                          Assuming I have remembered your email address correctly, one has just been sent to you.
                            it calls for an inspection and install ties as needed. the fuel cooler can clog and cause a hose to pop off. to access the cooler requires intake removal.
                              Thanks fellows...ties will be installed on all hoses without one.
