2000 60 hp C60TRLY
  • 2000 60 hp C60TRLY
    After cleaning carbs and installing, when I crank the engine, it goes wide open with no throttle control. What would cause this?
    Carb linkeages out of adjustment???
      are the throttle plates on carbs closed when this happens?
      might check then and also the timing linkage between the CDI and carbs
        I didn’t adjust the linkages because I never had to do this before. Just cranking in neutral, at idle position on the throttle and when I crank , it ru s away wide open. I even tried con*****ing it by hand to no avail??
          Anyone know where I can get a service manual without having to pay an arm and a leg?
            Find it here for free.
            https://www.vansoutboardparts.com/se...a-shop-manuals
            Should be under 2000 YAMAHA 60X / 70X / 75X / 90X Look three or four pages in from the first page to see a model list, I believe yours will be there.
              is there a reason you did not answer my question?
