F400? F500?
Hello Mr. Almetelo.
It is an F425. Direct fuel injected. 5 fuel pumps. Why not 8? I don't think I would have been bragging about 5 pumps. Some things are better left unsaid.
https://www.thehulltruth.com/boating...ere-425hp.html
should have made it with enclosed cooling and add another 35 lbs,Last edited by donsmarine; 05-17-2018, 01:57 PM.
To heavy!!!With more 50kg you have a 627hp from seven marine
Fortunately in not the problemtic block from the F350
I was expecting more... a supercharged or turbo motor.. Maybe in the future
Let way and see the results
Thanks for the news Boscoe
For some boats I suspect it will be the perfect companion. Yamaha does not develop motors in a vacuum. They coordinate and collaborate quite extensively with their boat builder partners. Probably would not have been developed if boat builders were not expressing a need for it.
Boats come first, then the motors. Same with air planes.
The weight of the motor up against a 40' ~ 50' boat is a non-issue.Last edited by boscoe99; 05-17-2018, 03:41 PM.
