I have twin 2004 four stroke 115 outboards and one trim guage quit working then the other quit. The sensors look fine. On the pink wire connector at the tach was a tag reading (If this tachometer is used for 2003 and earlier model F30,F40,F50,and F60, disconnect the pink lead coupler attaching this tag.Otherwise, the trim angle display will malfunction. Have a waterproof treatment to the disconnected couplers) My pink couplers were connected but I am wondering if that caused the trim guages to quit. Talking to a mechanic and he said unplug the pink wires but that did nothing. If I replace the tachs are the pink wire couplers left disconnected? Thanks
trim guage on tach not working
The trim sensors are known to stick. The engine moves them in one direction and a spring moves them in the other direction. Have they been cleaned and lubricated and do they work freely in both directions?
Also, there is a device known as a trim cam that the sender pushes against. Early engines used a plastic cam that is known to break. If it breaks there will be no indication on the tachometer. Check the trim cam. The updated version is made of stainless steel.
Item number one in the following link
2004 F115TLRC Yamaha Outboard BRACKET 2 Diagram and Parts
It is always helpful if you provide the full model of your motor. It is an F115TXRC. I think.
