Propeller torque - please help
  • Propeller torque - please help
    The owner manual say do not torque the prop more than 33 ft-lb. The problem is I cannot see the hole for the cotter pin. Should I go without cotter pin or exceed the recommended torque to look for the cotter pin hole? Thank you in advance for your help. Vincent
    go to the next hole, never loosen it,, I always torque to 35 lb/ft then go to the next hole.
      go without cotter pin and you will go without your prop
      put it in
