Anyone have any comments on 225 excel 1998 no spark issue. thing to look at before replacing parts.
225 Excel No Spark
Pick up a service manual for the motor, the proper testing equipment, and start testing the ignition components.
Kill switch,key switch, and wiring to them would be the 1st things I would look at.
But you need to make sure charge coils are putting out in spec voltage if this motor uses themLast edited by 99yam40; 02-18-2014, 10:33 PM.
1989 225 Carb work
Ok, Do i feel DUMB. spark prolbem solved. New Question, 6K7 UL 702868 research come up as 1989 Excell 225. is this true? Motor sat for 11 years, I have it starting but will not ideal. Carb cleaning next on list, any do's and don'ts I should be aware of ? Last owner used pre-mixed gas and injection systen at the same time. Carb's are full of black tar so to speak of.
change/carefully clean All fuel lines. replace the fuel pumps.
replace the water pump t-stats and pressure control valve grommet.
change/inspect the gear lube.
sometimes you only get one shot at an overheat.
mark the remote tank level.
run it on premix and insure the tank level drops.
do NOT mark the engine tank, mark the REMOTE tank.
pul the stop lanyard,crank engine listen for horn operation.
ÂÂ
