1996 130TLR will engine run without oil control unit or gauge?
  • 1996 130TLR will engine run without oil control unit or gauge?
    My 130TLR is missing the oil control assembly and onboard tank gauge. I'm wondering if it'll run without the oil system inputs? The oil tank and pump are still there, but I'll block it off and run it on premix.
    Why not just fix it and run it as it was designed?
      I bought it cheap on gumtree and I want to make sure it runs before I spend any money on it. The guy that sold it to me said it was seized, so I bought it just for parts. But it's not seized and is in fair condition, apart from a few bits missing - the oil control unit and tank gauge, one of the tilt-trim relays, and the wiring harness 10-pin connector. If I can get it running without the oil system then I'll buy the bits I need, but don't want to buy them and find out there's something major wrong with it.
