alternator part information
  • alternator part information
    what alternator fits my truck ?
    come on man, you know we need a model number,
      and I also know you are making a point, and a good one at that
        Maybe the belt's slippin'.....sounds like somethin's slippin' for sure!!
          I thought his kind was gear driven.
            why do alternators keep coming up when Rod has been drinking cool-aid
              Mostly likely a big one since it's in a truck and not a Yamaha outboard engine
              Retired and Loving Life
                The blue one...... unless it's a red truck....
                  If the Bare rings are good, throw a new diode trio and voltage regulator at it.
                  Then you don't have to buy an expensive new one.
                    the truck is black if that helps .
                      If the truck is black you will need the chrome one.
                        What is a Bare ring?
                          Say it fast.
                          Bearing.
                          I heard it said that way by a guy that thinks a tool chest is a drawer with a screwdriver, hammer, and duct tape in it. In his mind a real mechanic will also have a pair of pump pliers.
                          Has Rodbolt found an alternator for a black truck yet?
                            I was thinking of the slip rings. Where the brushes ride for the field current.
                              I kind of thought you were thinking to hard about it
