Powerhead replacement
  • Powerhead replacement
    Need to replace my 2004 vmax 3.1L 200hp.
    best place to order from?
    quick turn around?
    thanks in advance.
    Replace or rebuild and YOUR location??
      www.chriscarsonmarine.com for a rebuild/remanufacture.
      www.boats.net for a new block.
      If we knew the model of the motor we could tell you if parts are available from Yamaha.
        Townsends FJR1300 which ever way would be
        the most cost effective?
          cost effective is a strange way of wording cheaper maybe
          , but are you looking for what is readily available close to you?
          Boscoe posted places to look with your proper model #
            Pine Crest Marine in Lexington,sc only a few miles from Columbia.....maybe go talk with them about it?....
              quick turn around?
              thanks in advance.
              http://www.boats.net/parts/detail/ya...100-03-1S.html
                That's JUST THE CRANKCASE..
                No crankshaft, pistons, rods, bearings, etc. (Not even a short block-Just the empty block)
                  you are correct... just looking and saw #1 is obsolete. 66X-W0090-15-1S
                    Boscoe and RB would know, but I've never seen a powerhead (complete) in the "parts section". But for warranty work, they are available for at least dealers..
                      Call Boats..net
                        If you are talking about what is known as a "dressed power head" they are not available from Yamaha as a spare part. Dressed meaning that it has everything on it that one would see if they removed the cowl from a brand new motor.
                        What Yamaha has been known to do is to take a brand new motor, remove the dressed power head, and send it to a dealers facility for a Yamaha mechanic to install same.
                          Thanks everyone for the input
                          i am look for a complete power head!
                          was looking to pull the blown one and installed new
                          one, my CFO ready for a boat ride!!
                            New power heads (undressed) appear to now be obsolete. No longer available from Yamaha. Part number 66X-W0090-15-1S that is, if that is the one that is applicable to your model.
                            I still have no idea what model motor we are talking about. You guys are so tight with models you should work for the White House to help stop leaks.
                              Z motor?????
