I was cleaning up and I saw some debris under one of the lower engine mount cheek plates. When I removed it, I found the motor mount dampner bolt head had rusted away. There's still just enough to retain the bonding wire terminal end.
So I'm going to order some bolts. I inspected the other side and it is in pristine condition. I removed / inspected the port engine too and found the same situation. Interesting. Both of the port bolt heads on both motors are gone. The rest of the hardware appears to be clean, just the two portside bolts on both engines. Electrolysis?
Item 20 BRACKET 2 $18.21 a piece...
Year 2000 SX/LX150TXRY
