wiring
  • wiring
    I have a 1999 c40trlx i bought this boat and the wires are unhooked from the ignition switch it is an after market switch as well i have no idea where these wires go ? the letters i have on the switch is A,B,C,M,S I'm not sure where to put my wires yellow,black,white,blue,brown,red. Or can someone recomend the correct ignition switch?
    Ok first starting with yamaha harness . yellow = key on , black = ground , white = magneto or kill wire , blue = choke , brown = crank , red is 12V to switch .i think u should have 2 M's also . so Yellow goes to A , Black to M , White to other M , Blue to C , Brown to S , Red to B For future ref. A=Assy B=Battery C=Choke M=Magneto S=Starter . Cheers
      Thank you
      Thank you so much ill give it a shot in the morning thanks again liliepad
