I'm assisting a friend who has 2004 F150's. He wants to replace the round gauges with the newer square ones. Are the square gauges plug and play with the existing wiring harness and the F150?
Square gauges are known as Command Link. These use a digital data bus to receive engine data versus analog wires.
A 2004 F150 (or Yamaha anything) does not support Command Link gauges, square or round. That is, Command Link gauges simply will not work with your friends motors.
