Hi everyone,
I have a 1998 140hp (Australia) V4 2 stroke Yamaha that I have been installing on my boat myself. I made a mistake with the wiring of the battery leads, where I connected the negative battery cable to the bottom of the starter motor and the positive to the starter solenoid, I know, pretty stupid
Anyhow, at this stage I began trying to turn the motor over, I was getting a grinding sound from the starter solenoid with no starting, however, tilt and trim was working perfectly. Once I discovered what I had done with the battery cables I changed things around to how the manual shows and now the motor is starting and running beautifully. At this stage I tried to tilt the motor and nothing... I tried both switches and all I got was a click from the upper (raise) tilt solenoid, the lower one I was only getting clicking from the remote, the switch on the motor is doing nothing, there is also no response from the tilt motor, I have recently tested the tilt motor and it works fine, thankfully. I replaced all solenoids and am still having the same problem, I also managed to fry the tach in the process and have replaced that which has done nothing.
I am pretty desperate for any help anyone can provide, I have looked on the site for the solution, to no avail, so if anyone has seen this fixed on here before please let me know where to find the thread.
Thanks very much everyone.
