Yes the IAC is clicking on shutdown, thank you for that info.
i disconnected at the primer bulb and used the primer bulb on my 12 gal tank. I guess it is possible there is a restriction not allowing enough fuel? I know some was making it to the fuel rail and injectors, had 45 psi and saw fuel coming out injectors when i was still troubleshooting. Will definitely check before i hook back up to main tank.
