f-115 injectors and vst questions
  • f-115 injectors and vst questions
    I have a f-115 built 10/05 and have a few questions.
    1. I just received my injectors back after cleaning. Do I insert them dry, or should I lightly coat the o-rings with oil?
    2. I want to replace my vst filter. I have the vst filter, the manifold gasket and the large o-ring for the vst tank. Will I need anything else? I see that there are a couple of hose clamps that are not re-useable. will I need to remove them? any other non reusable parts that I need to be aware of?
    3. Any other hints or pieces of advice from those that have done this before?
    Thank you,
    Louis
    light oil or engine oil on the orings.
    vasoline if nessasary on the VST gasket.
    I use dabs of grease to help retain the intake gasket to the head.
    if not damaged the intake gasket can typically be reused.
    any oeticker style clamp you cut off MUST be replaced by the CORRECT style clamp. NOT a standard worm type clamp.
    other than that its typically 1.5-2 hours worth of worky worky.
      Thank you Rodbolt. Are there other sources, besides Yamaha, for these clamps?
      Thanks Again,
      Louis
