I have a 225 HPDI and am losing lube oil from lower unit. I suspect either the prop or drive shaft seals. How difficult is it to replace and what tools are needed? For the prop shaft, do you have to remove the bearing cage? I would really appriciate any help on how to proceed.
Oil Seal Replacement
Originally posted by amahaorkhow much you going to save by diy? replacement gear case ~1k
it is possible to remove seal without removing carrier by using screw (yes, wood screw), but most likely 99.9% chance you will damage prop shaft at the place where seal runs. nobody will recommend it to you. how much local shop quoted you for re-seal case? you may do it yourself but must have all tools not to damage gear case. having special tools are the only way.
60V-45300-20-8D YAMAHA LOWER UNIT ASSY $3546.50
I agree with you, this is not the type of part for a backyardigan type repair.
Originally posted by rickboat View PostBoth seals are leaking. I am looking for the best way to replace. The manual seems to say that the bearing cage should be removed for the prop shaft seal. There must be a simpler process.
Now someone somewhere will have done it in an inappropriate manner. Maybe they got lucky and maybe they did not.
If you are willing to gamble a multi-thousand dollar gear case then get a screw driver and start trying to pry the seals out.
This video(s) helped me when replaced oil seal on my 30HP
Lower unit seal replacement pt 1 of 3 - upper seal experiments - YouTube
