F300 Port Bank not firing at idle
    and you will find, as I have stated before. there is nothing that controls ign or fuel bank to bank like the old OX66 or 3.1L carbed motors.
    why not simply use the correct test equipment and test it?
      I don't see the intake valves being fully advanced or retarded due to a failed VCT mechanism as resulting in the cylinders on that side failing to fire. If that is what has been suggested.
        sorry I must have misunderstood original post that said found left bank coils firing and injectors misting.
        • #19
          Hi,
          sorry didn't manage to make it to the boat today. I'm on a small island with very limited tools, if needed I can probably find or order a scope,
          Boscoe, with the engine running in gear around 4000 rpm, unplugging VST solenoid on that bank you can really hear the engine bog down, I'm satisfied that the cam is retarding/advancing as intended, I only changed it out of frustration, I was in there anyways to check the timing marks and change the timing belt.
          Spark plugs looks surprisingly dry, very light brown. I'll try to post some pictures, the engine starts so easily, I'm thinking that bank must be helping somewhat initially and then fails? Idling for a few minutes and you start to smell unburnt gas.
          just to try and be clear again,
          have spark, have fuel, have compression, but there is no power stroke on that bank until approximately 2500-3000rpm. If I unplug all three coils/injectors in that bank at idle, there is absolutely no noticeable change in the engine. If I plug those back in and start unplugging the opposite side, engines starts to stall immediately and with two unplugged with stall completely.
          Rodbolt, what test equipment would you suggest?
          I'd consider buying it and shipping it down,
          thanks
          travis
          • #20
            I would suggest a fuel rail pressure tester,a Kv tester,YDS and a DVA adapter.
            • #21
              Make sure the gauge or gauges are oil filled.
              • #22
                Thanks, I'll work on this and post back any results.
                Cheers
                travis
                • #23
                  What its result??
                  • #24
                    Why is it you go to ANY boat Race,, and all are runinning Merc's
                    • #25
                      I’m the exact same problem as travis in this thread. The thread went cold. Anyone have any answers? I have same issue, tried same solutions. No luck
                      • #26
                        I’m having the exact same problem as travis in this thread. The thread went cold. Anyone have any answers? I have same issue, tried same solutions. No luck
                        • #27
                          I had this problem. It was the oil control valve for the cam
                          • #28
                            It is frustrating when posters abandon threads. Thanks BaJA, great input!
                            • #29
                              I had the same problem and it was also the OCV system on the non firing bank. In my case it was a side effect of cracked cylinder heads. You will definitely want to make sure the OCV problem is not a symptom of larger problems. The OCV valve gaskets have a built in filter screen. This is a good time to ask the question why would there be a local filter protecting the OCV valve? Because its fed by oil that, if other parts of the motor start shedding metal, will make the OCV system fail due to its very tight clearances. Under normal circumstances and assuming you run decent oil that screen should NEVER be clogged. Only reason I can live with for a failed OCV system is if the solenoid coil has failed.
                              Good way to verify its the OCV is if the non working bank starts working at about 2500+ RPM.
                              Chris
                              2004 GW 330 Express w/ Twin F225's
