F225txrd
Seized manual valve removal
I appreciate all the attention this thread is getting however I still haven't had light shed on the issue I'm having.
The screw is seized and I'm asking for methods for removing or freeing up the manual valve screw.
I'm sure I'm not the only one who has come across this issue and I'm hoping to pay it forward and help anyone else in thr future who had the same concern.
Originally posted by railroad124 View PostI appreciate all the attention this thread is getting however I still haven't had light shed on the issue I'm having.
Let's wait and see what rodnut sez.
Originally posted by walleye1 View PostSome of those manual releif valves are left handed thread.
To make myself clear, after you remove the retaining clip you would turn the whole thing clockwise (left hand threads) to remove it from the T/T unit body?
Maybe we got our wires crossed up here, so to speak...
this is it?
I suppose the inner o-ring retains the hydraulic fluid when the valve is "open"
and the outer o-ring is intended to keep water out of the threads
but if it fails to do so...
Rodbolt is saying inside this thing is a ball and rods? I'm seeing it listed to be a $150 part...
Walleye are you saying that the whole valve Assy may possibly have left hand threads? Not the screw in the valve assy that you turn counter clockwise to lower the engine?
The picture Fairdeal posted has right hand thread..that would only make sense.
have I ever seen stuck valves???
dude this marks my 27th consecutive yr of dealing with outboards in the salt pond.
nope I have never seen a corroded part.
can I get violent with them? yep.
not the first one I have drilled and tapped for a left hand thread and used a bolt to back it out.
Originally posted by rodbolt17 View Postnot the first one I have drilled and tapped for a left hand thread and used a bolt to back it out.
I have used a left handed drill bit, at very low speed - when it started to bite, the stuck threads backed out -
but actually tapping for a left handed bolt - brilliant.
