Does anyone happen to know where on the side of the casing (is it called the "midcase") I could cut a hole to access the spot where the driveshaft splines into the bottom of the crankshaft?
Or, instead, does anyone know how long the driveshaft is - maybe in terms of how far the driveshaft extends vertically above where the lower unit separates from the midcase?
I can find pictures online that tell approximately where the driveshaft is, front to back. It appears to be roughly inline the forward edge of the "grooves" for the water inlet opening. But I'm not sure how tall the driveshaft is. Worst case, I can make an estimate with a hole just big enough to stick a snake cam in there.
