2016 Yamaha F150. I noticed that on the right side of my swivel tube it has been grinding against the clamp bracket. Is there a spacer made to resolve this? The left side of the parts is not touching.
Swivel tube and clamp bracket grinding
I think the existence of that part put into the design means that both sides should just be "touching" to guide or hold in place the engine against side forces of a turning engine as it is tilted out. (Or simply the rotation torque of, or giroscopic force on, the engine pushes it that way). That is, to take away excessive force or twist on the tilt pin.
I think if yours looks like the above, you may have excessive wear at the tilt tube, or your engine setup is such that your using a lot of tilt. Your suggestion of spacing may well be correct. Check also whether the brackets are also firmly bolted to the transom, as those bolts also play a part in holding that part of the outboard together.
I need to point out that the photo I posted is of my F225TXRD (because it was available)
although it served to indicated the general area the OP is interested in, is not his model.
HOWEVER - seems from a quick look at parts listings - there is a "yooge" difference in design in that area
- appears to be below 200 hp, vs 200 hp and up
here is a F150
and my F225
notice the much larger surface area of the brackets on the larger motor -
and the additional parts: polymeric "friction washers" parts # 12 and 15 on the drawing:
