Good afternoon,
I have a 2001 80hp 4 stroke with approximately 350 hours on it. I ran out of gas and after I refilled it the boat will not start. I took cover off and the starter will engage the flywheel ut the flywheel does not budge. I think the starter might be bad from lack of use ie corrosion etc but if there is a simple fix please advise.
Ps I tapped on the starter within wooden handle and the starter will turn the fly wheel a bit now!!the battery btw is good as the trim and tilt works
Jim
Clermont, fl
Jim
Clermont, fl
