I have a 2000 50 hp 2 stroke Yamaha. It use to run fine but every so often you would hear a chirp and it would bog down and after a while it would run fine, now it has gotten so bad that when you started it it would run for a few seconds,chirp and turn off. Every time it does this noise there is a release of bluish smoke coming from the bottom of the block toward the middle. I was told this could be a leaking gasket by the reed section of the engine. Like I said, this was a small problem before but now I can't keep the engine running any help would be greatly appreciated
2000 50 hp chirps and shuts off
the chirp is a lean sneeze caused by fuel/air mix being too lean.
Carbs or the prime start enrichment system has plugging problems
or leaking air in where it should not causing it to lean out.
The fuel mix in the crankcase gets burned before it reaches the cylinder,
when that happens it can rupture fuel pump or other diaphragms or pop gaskets /seals from over pressure of crankcase
If that part was the prime start heater, did you test it before buying new?
may have just been trash in passage that got removed when replacing it.
Does not realy matter as it is running OK now, but if someone else is looking for what will fix theirs it is nice to let them know to test as the service manual calls for
Originally posted by 99yam40 View PostIf that part was the prime start heater, did you test it before buying new?
the above thread link you responded in is exactly what i am experiencing .
what part was replaced . i cannot see that in the answer ?
fuelpump ?
thx for the response
Â
