skip the oil.
tends to flash over when you heat it.
yep your gonna have it hot enough to flash most oils.
the gear oil that is left in the case will be boiling.
if it aint boiling the oil your no where near hot enough typically.
might be best to use the dealer locator function and take the case in for disassembly.
make sure the dealership has at least 1 master tech.
