Hi! Searched forums but have not found the solution for this outboard. I'm in process of converting a 2008 F15 CPLH from tiller to remote. I purchased the conversion kit, which made the mechanical portion easy. The electrical has proved more challenging. I was led to believe there would be a pigtail wire harness connection in the carcass, but there is not.
I should note at this point that I'm connecting this outboard to a Morse style connector with separate panel mounted tilt and ignition switch.
There is a bullet connection organizer/holder which appears to have most of the relevant connections. The tilt mechanism had a clip.
Is there a 10-pin harness that connects directly to this ouboard or is there a pigtail that wires in and then allows connection to the typical Yamaha 10-pin connection?
I phoned the service departments at two Yamaha dealers in the last two weeks, including the one where this outboard was originally purchased. Both said they would phone back after touching base with Yamaha techs, but have not heard back from either. Appreciate any help in completing this conversion!
