Yamaha 70TLRB
  • Yamaha 70TLRB
    What can cause over heating on a 70hp two stroke at idle speed, in gear? The water pump has been completely rebuilt, including a new pump housing. Water jacket removed and cleaned. Thermostat replaced. Blew compressed air through water lines and hoses.
    Any ideas would be much appreciated.
    The 70HP has an high volumn low pressure system, it does take a lot of water to keep it cool, small problem in water pump or in cooling passages can cause it to overheat
