Somebody Explain this to me Re: T-Stats Question
  • #76
    HMBJack, of course you are smarter than a Yamaha engineer, they have not solved this problem. You will achieve improvement.
    To be fair to Yamaha individuals their work is con*****ed by a big corporate machine that usually needs only to achieve minimum performance for least cost; they tend to make one size fits all.
    You have the luxury to experiment make your one engine meet your needs. And trial and error is available to all of us whether we are engineers or not.
    • #77
      Getting more fresh water to the other side of the stats W/O any compromise sounds like a winner to me.
      Could Yamaha have done this, sure... That engine might last another couple of years= No new engine sales
      However, there is a planned lifespan for most anything nowadays.
      The exhaust stack failure was a big boo boo for Yamaha.
      Next time I have my thermostat out, the vent hole will get drilled...
      • #78
        well, "everything else being equal" -
        the engine with a bigger bypass in the thermostat is going to take longer to warm up
        and "run colder" until it does
        although "in my neck of the woods" - where "cold" means the seawater temp is just below 70F ....
        • #79
          Let's say you want to get maximum life out of your Yamaha four stroke, specifically the 3.3L V6.
          Assuming you do all the recommended maintenance by the book - we can all mostly agree on two areas of weakness:
          1. The Dry Exhaust Manifold, and
          2. The Thermostat Bore
          In February, I took care of #1 with my local Yamaha Mechanic. No corrosion found anywhere by the way in my pair of 2006 F250's (1,475 hours). But now I can sleep at night not thinking about that.
          As to #2 - this post details everything.
          I truly feel my modified T-stats (with weep holes drilled) will help minimize salt crystals & corrosion in the T-stat bore. But if you flush with only the garden hose fitting, you need to have really good water pressure. If your water pressure is less than good, or you want to be super sure you're getting FW through your T-stats, then simply flush with the muffs. I believe this practice + annual inspections will take care of any issues in the T-stat bore.
          Now, because of the weep holes (vents) in my T-stats, yes - my engine will warm up to operating temperature slower. But if this was much of an issue, I should see that in my fuel economy - which I don't so far. I idle out of my harbor for a few minutes then, once in the ocean, I put the coals to my F250's to achieve cruising speed. Water temps here are at 55 degrees all year long. So, in my case, no "under heat" scenario and no side effects as far as I can tell so far.
          Grady-White 330 Express
          • #80
            Very true, ^^, but the water temp here (now), (SW Florida) is 80F and gets into the high 80's due to the shallow Gulf of Mexico, and shallow river before I get there..
            Even during winter, the water temp might be 65F, my engine takes maybe takes 2 minutes to idle down from 800 to 700 (normal idle).
            That vent hole is pretty small and if a slightly larger hole allows more fresh water (or ANY fresh water), to get in there, I don't have a problem with that at all..
            Lastly, consider how much more water flows thru the fully OPEN thermostat vs the slightly opened hole...
            • #81
              I slapped new T Stats in my 200-hour engines last summer before this thread grew legs and hauled itself out of the swamp. Much to my dismay and severe disappointment, they were all crudded up with salt, and there is already corrosion evident in one of the thermo bores. At that time I did not know of the proclivity for the head to consume itself. So, I cleaned it all up and slapped in the new T-Stats.
              Thanks for posting the photos. At some point this year, I will pull mine and drill holes as you did. I will also do what I can to the corroded bore before I button it all back up.
              I do not have access to city water where I keep my boat. Well-water only, and then only for about 9-10 months of the year since freezing pipes is a problem. So when I want to use the boat in the winter months I don't have the ability to flush. And when I do flush, its at well pressure, not city water pressure. Needless to say, this salt issue is huge to me and anything, no matter how trivial that improves my odds against corrosion is a worthwhile endeavor.
              • #82
                The only issues with the 3.3L V6's are:
                1, The Dry Exhaust Manifolds - which you can fix with your MasterCard or Visa with your Yamaha Mechanic, and
                2. The Thermostat bores . This post - if you read every page - will educate you on that. Drilling holes in your T-stats is not a bad thing. You for sure get more FW flush water passing through your T-Stat bores. In my case I have decent water pressure at my slip. But to be very sure, when I can, I now flush with the muffs+ the garden hose fitting. I am very very sure I am flushing my T-Stat bores better than before.
                • #83
                  You forgot,
                  3. The stalling at idle issue.
                  • #84
                    Old Mako
                    I haven’t heard of that one. What’s the fix?
                    • #85
                      I can see a thermostat modification being desirable for some motors in some applications. A motor running in salt water that is nominally 75 degrees is going to be different from a motor running in fresh water at 40 degrees. I suspect motor designs (and maintenance plans) are structured for average use in average conditions. One size might not fit all.
                      • #86
                        Originally posted by oldmako69 View Post
                        You forgot,
                        Yes, what is the stalling issue about? Have not heard of this one.
                        • #87
                          I’ve owned 3 F225’s and 2 F250’s for a collective 2,300 hours of use by me personally and I have never experience a stall at idle.
                          No worries on a thread de-rail. I think we’re all curious.
                          • #88
                            I went back and read this entire thread again. Very entertaining. So I coated the body or shoulders of the brass thermostat on my F-150 with Flex Seal. Yes, the stupid commercials on TV. About 4 years ago. I was having major pitting in the bore. I’m replacing for the first time tomorrow. Inspected many times in the last 4 years and no new corrosion. OP had a great idea.
                            • #89
                              I am the Original Post guy for this.
                              This is a very long and very old thread.
                              Fast forward to today, what I learned is my crappy T-Stat bores (in photo on post one way above) was due to the previous owner of my boat NEVER ONCE flushing the engines in any way.
                              I bought the boat with 312 hours. And the previous Owner had it for 4 years. No flushing IMHO. So - I inherited salty T-Stat bores.
                              In my thousands of hours of use since 2010, I have learned the key to flushing a Yamaha, or any outboard for that matter, is to flush it immediately when you turn off the motor.
                              No Salt Away, no Vinegar, no muffs, no water tank - just flush it with FW while the engine is still HOT.
                              Since doing this, when I inspect my T-Stats after one or two years, they look perfect.
                              I wet slip my boat so this is easy to do when I return from a trip. I connect the FW flush hose practically before I tie my boat to the dock.
                              But I swear, what I'm saying here is true. Over and over again, my T-Stats look perfect after 100% repeated flushing when the engines are HOT.
                              Not sure what I'd do if I trailered my boat.
                              By the time the boat gets up on the trailer, the powerhead will cool down thus making a flush ineffective (or at least less effective) since the T-Stats will close up.
                              • #90
                                I only flush at end of season (with SaltAway solution) but when I do I remove thermostats......
