I had let my outboard sit for a year and it just wouldn't start ... I was suspecting an electrical issue.
The guys on the forum had me go through the following process.
It turned out I did have a bad high pressure pump.
This is the process i went through...
1. Remove one plug... check for spark
2. CAREFULLY... try to start engine on ether... if runs... then positively fuel issue
3. Pull the hose attached to VST pot... pump bulb... fuel comes out... it is electrical issue with high pressure pump
4. Test for 12 volts DC at positive wire on injection pump wire to ground... result of test... Relay is closing... and all three fuses are good.
5. Test for voltage across pump... if voltage shown... pump is probably suspect.
6. Remove drain plug on VST... if fuel drains... pump again suspect... replace and reprime
7. CAREFULLY release pressure from schader valve...
8. Remove hose to rail.. Engage pump... no fuel... pump is issue..
9. Remove VST... check pot for clogs... pump is dead
10. Don't freak out over price at Yamaha sites... Look for pump on Ebay... 10% for non branded pump vs. Yamaha price
Follow this sequence... 2 hours for testing and ordering pump max.
__________
It is best to get yourself a service manual for your motor. Then you have the resources to work on your particular motor.
The troubleshooting tree is list for each problem.
There is also a list of issues and all items that can cause the particular issue you are addressing
You need to have model number such as …. 2004 Yamaha outboard 200hp (SX200TXRC)
You can find the part number… literature parts number (something like LIT-18616-02-80) at
https://www.yamahapubs.com/
Manuals can be found at…
https://www.vansoutboardparts.com/se...a-shop-manuals
Note: i was a bit confused
I had questions that I had the correct manual…
some numbers or letters may be dropped on front of manual
manuals serve for several different motors… SX200C was shown on my manual (dropped the "TXR" in my case
I AM NOT A GENIUS... this is just a summary of how they instructed me to the issue....
This might not be your solution... if one of the steps... like the relay being bad... or it does not start on ether.... keep asking...
THESE GUYS KNOW EXACTLY WHAT THEY ARE DOING... AND I HAVE NOTHING BUT RESPECT FOR THEIR KNOWLEDGE AND HELP
__________
