I have a new F200 in line 4 that is connected via nmea2000 to a garmin 740s. I see all the engine data but hours, do the 2013 f200's send that data, if so, how can I get it to display on the 740s ?
2013 F200 engine hours
Yes, the engine's ECU sends hour data to the chart plotter along with all of the rest of the engine data that it sends. I suspect this is something on the Garmin side that needs to be addressed.
Are you seeing an "hours" field with no data being shown are do you not see an "hours" field?
Have you talked to Garmin? The owner's manual indicates that not all options are available for all gauges, whatever in the hell this means.
