I have a 2005 f225 with nmea 2000 connection (has the plug and 31 on the ecu) I just hung the engine and am trying to figure out which plugs to connect.
2 green wires plunged into 4 pink wires. The last trim indicator (the top one) on the tach is blinking along with I believe the oil level indicator. I did order a new four plug harness to try out.
Also there is a red 10 gauge wire with black plug hanging there also where the 10 pin is. This motor was part of a twin and think its some sort of power for the other.
The engine that came off the was a 1999 150 ox66 with a burnt up rod bearing.
Thanks for the help.
